Learn About Record to Device in Memory Zone for iOS on iPhone 16, 15 Pro and Pro Max
Record ProRes video on a supported drives with an iPhone 16, 15 Pro and Pro Max.
IMPORTANT:
  • Password-protected drives are not supported.
  • The drive format must be exFAT.
  • Phone connection adapters are not supported.
Need more help?
  1. Download and install the app.
    SanDisk Memory Zone for iOS
    Third-Party Notices: iOS
  2. Connect the drive.
  3. Open the app.
  4. Tap the Drive.
  5. Tap the 3-dot menu.
  6. Tap Record to Device.
  7. Turn on ProRes video.
    • Tap Settings.
    • Tap Camera.
    • Tap Formats.
    • Tap turn on Apple ProRes.
    Need more help?
    Apple Article: Record ProRes videos with your iPhone camera
  8. Tap Record to Device.
  9. Tap Confirm.
  10. IMPORTANT:
    The drive will disconnect from the app when it goes into USB On-The-Go (OTG) mode.
    Need more help?
    Answer ID 52008: FAQ About Memory Zone for iOS and Android
  11. Start recording.
    1. Open the Camera App.
    2. Select Video mode.
    3. Turn On ProRes. (default=off).
    4. Tap Record.
  12. STOP Critical:
    Video playback will be poor on drives with slow write speeds when using 4k/60 frames per second.
    Use HD/60 for better quality.
    Need more help?
    Apple Article: About Apple ProRes on iPhone
  13. Open the Files or Camera app to see recordings.
    Need more help?
Details
Answer ID 52007
Published 09/14/2024 11:16 PM
Updated 03/20/2025 06:46 AM
