"Find out what the blinking white, blue, or solid amber LED lights mean on your WD My Cloud storage device."*END
Description
My Cloud is not found, cannot be detected, or accessed while the power LED is blinking.
A System Restore, reboot, or abrupt loss of power may take longer before it is ready to be used.
The file system check may be running or the reboot process may not have finished yet.
Power LED Table
Status | Code | Title | Power LED |
Critical | 1020 | System Shutting Down | Blink Blue |
Warning | 1037 | System Not Ready | Blink Blue Blink White Solid Amber |
Informational | 2024 | Downloading Firmware Update | Blink Blue |
Informational | 2026 | Installing Firmware Update | Blink Blue |
Informational | 2032 | System is in standby mode | Pulse Blue |
Informational | 2033 | System Rebooting | Blink Blue |
Informational | 2020 | System Shutting Down | Blink Blue |
Need more help?
Answer ID 17203: LED Status, Alert Codes, Descriptions, and Email Notifications for WD My Cloud
Resolution
Power Cycle (No Power Button)
- Remove the Power Supply from the power source.
Wait 3 minutes. - Connect the Power Supply to the power source.
- Press the power button.
This will power up the My Cloud.
Power Cycle (2 and 4 Bay with Power Button)
- Press and hold the power button.
Wait for all LED to turn off. - Remove the Power Supply from the power source.
Always Blinking White, Blue or Solid Amber LED
- The file system check is still running or stalled if the power LED is blinking white, blue or solid amber.
It is not ready to be used.
There could be file system or hardware errors. - The file system check MUST BE allowed to completed
PLEASE WAIT!. - IMPORTANT:
Doing a System Restore or power cycle will force the file system check to start from the beginning.
The process can take up to a few or more days depending on the size of the drive, content and data.
Warranty Replacement and Data Recovery
Need more help?Answer ID 33498: Western Digital Warranty Replacement and Data Recovery
